Introduction
This is Part 2 of the Project with the same title.
Summary of Part 1
Part 1 microPython program now has 4 python modules:
Pico system Uart
HC12 RF xmit/recv
TB6612FNG 4WD motor driving
Pico system interrupt
# *** pico_4wd_v90.py - tlfong01, 2021nov19hkt1719 ***
# Brief Description
# 1. Smart 4WD based on Rpi Pico, TB6612FNG, DC/BLDC motors, 433MHz HC12, 2.6GHz BLE HC02, Androd smart phone with
#    acceleromter and magnetometer
# Contents
# 1. Pico 4WD with TB6612 DC Motor Drivers and gear encoder motors N20, tt130, and TM310
#    1.1 Interrupt functions
#    1.2 DC motor function
# 2. Pico 4Wd with BLDC motors with built motor drivers (ie, TB6612FNG is not required
# 3. HC12 433MHz RF transceivers
#    3.1  uart loop back functions
#    3.2  HC12 transmit/receive echo functions
# 4. HC02 2.6GHz BLE slave modules
# 5. Integrating Parts 1, 2 with Parts 3, 4
from machine import Pin, PWM
import utime
# *** Pico GP pin assignments ***
uart0TxDNum  = 0 # HC12 #1 TxD
uart0RdDNum  = 1 # HC12 #2 RxD
hc12Setup1   = 2 # Reserved for SPI0 Sck
hc12Setup2   = 3 # Reserved for SPI0 Tx
i2c0Sda      = 4 # Reserved for SPI0 Rx
i2c0Scl      = 5 # Reserved for SPI0 Csn
# *** PWM Pins ***
aPwmPinNum0  = 6 #0
bPwmPinNum0  = 7 #1
uart1TxdNum  = 8 # HC12 #2 TxD
uart1RxdNum  = 9 # HC12 #2 RxD
aPwmPinNum1  = 11 #2
bPwmPinNum1  = 10 #3
# *** Inrerrupt Pins ***
intPinNum0 = 12 #4
intPinNum1 = 13 #5
intPinNum2 = 14 #6
intPinNum3 = 15 #7
# *** Motor Driver Control Pins (TB6612FNG) ***
stdByPinNum0 = 16 #8
stdByPinNum1 = 17 #9
aIn1PinNum0  = 18 #10
aIn2PinNum0  = 19 #11
bIn1PinNum0  = 20 #12
bIn2PinNum0  = 21 #13
aIn1PinNum1  = 27 #14
aIn2PinNum1  = 28 #15
bIn1PinNum1  = 22 #16
bIn2PinNum1  = 26 #17
# *** Interrupt Pin Dicts ***
intGpPinNumDict = {'0': intPinNum0,
                   '1': intPinNum1,
                   '2': intPinNum2,
                   '3': intPinNum3,
intPinNumList = [intPinNum0, intPinNum1, intPinNum2, intPinNum3]
# Comments
# 1. There are 4 GP pins to read interrupts: intPinNum0, inPinNum1, intPinNum2, intPinNum3.
# *** Sleep time dicts ***
secondsDict = {'OneSecond'    :   1,
               'TwoSeconds'   :   2,
               'FourSeconds'  :   4,
               'TenSeconds'   :  10,
               'SixtySeconds' :  60,
               'ThreeMinutes' : 180,
def hold(secondsName):
    utime.sleep(secondsDict[secondsName])
    return
# Comments
# 1. Hold function is friendly version of utime.sleep.
# *** Interrupt global variables and dicts ***
global intCount0
global intCount1
global intCount2
global intCount3
intCount0 = 0
intCount1 = 0
intCount2 = 0
intCount3 = 0
intCountDict = {
    '0': intCount0,
    '1': intCount1,
    '2': intCount2,
    '3': intCount3,
# Comments
# 1. There are four global variable to hold interrupt event counts.
# 2. For this 4WD, the four interrupt signals are the four motor's rotary encoder output signals.
# *** Interrupt Callback Functions ***
def intCallBack0(pin):
    global intCount0
    intCount0 = intCount0 + 1
    return
def intCallBack1(pin):
    global intCount1
    intCount1 = intCount1 + 1
    return
def intCallBack2(pin):
    global intCount2
    intCount2 = intCount2 + 1
    return
def intCallBack3(pin):
    global intCount3
    intCount3 = intCount3 + 1
    return
intCallBackDict = {
    '0': intCallBack0,
    '1': intCallBack1,
    '2': intCallBack2,
    '3': intCallBack3,
def countIntPinIntPeriod(intPinNum, countPeriod):
    global intCount0
    global intCount1
    global intCount2
    global intCount3
    intCount0 = 0
    intCount1 = 0
    intCount2 = 0
    intCount3 = 0
    utime.sleep(countPeriod)
    if intPinNum  == 0:
        intCount = intCount0
    elif intPinNum == 1:
        intCount = intCount1
    elif intPinNum == 2:
        intCount = intCount2
        intCount = intCount3
    return intCount
def countIntPinNumListIntPeriod(intPinNumList, countPeriod):
    intCountList = [0] * len(intPinNumList)
    for index in range(len(intPinNumList)):
        intCountList[index] = countIntPinIntPeriod(intPinNumList[index], countPeriod)
    return intCountList
# Comments
# 1. countIntPinIntPeriod(intPinNum, countPeriod) is to count the number of interrupts at the interrupt pin denoted by the
#      interrupt pin number.
# *** Test functions ***
def repeatCountIntPinNumListIntPeriod(intPinNumList, countPeriod, pauseTime, repeatTimes):
    print('\n  countIntPinNumListIntPeriod()')
    intGpPinNumList = [0] * len(intPinNumList)
    for index in range(len(intGpPinNumList)):
        intGpPinNumList[index]     = intGpPinNumDict[str(index)]
    print('    intPinNumList           =', intPinNumList)
    print('    intGpPinNumList         =', intGpPinNumList)
    print('    countPeriod (seconds)   =', countPeriod)
    print('    pauseTime (seconds)     =', pauseTime)
    print('    repeat count times      =', repeatTimes)
    print('')
    for count in range(repeatTimes):
        ppsList             = countIntPinNumListIntPeriod(intPinNumList, countPeriod)
        print('    countList =', ppsList, end = '')
        print(' , min ', min(ppsList), end = '')
        print(' , max ', max(ppsList), end = '')
        print(' , dif ', max(ppsList) - min(ppsList), end = '')
        print(' , avg ', int(sum(ppsList) / len(ppsList)))
        utime.sleep(pauseTime)
    return
# Comments
# 1. repeatCountIntPinNumListIntPeriod(intPinNumList, countPeriod, pauseTime, repeatTimes)
#      repeatedly counts and prints tinterrupt events in countPeriod and p
# *** Part 3 - TB6612FNG Motor Driver Functions ***
# Comments
# 1. This 4WD uses two TB6612FNG DC motor drivers, each with two driver channels, with a total of 4 channels for four motors.
# 2. BLDC motor have built in motor drivers, therefor is not handled by TB6612 motor driver.
defaultDirection = 'Forward'
defaultSpeed     = 'VertHighSpeed'
defaultPwmFreq   = 1000
defaultDutyCycle = 90
dutyCycleDict = {
    'VeryVerySlow' : 95,
    'VeryFast'     : 90,
    'Fast'         : 80,
    'Normal'       : 50,
    'Slow'         : 40,
    'VerySlow'     : 30,
    'VeryVerySlow' : 25,
motorConfigDictDict = \
        '0': {'MotorDriverNum': 0, 'ChannelNum': 0},
        '1': {'MotorDriverNum': 0, 'ChannelNum': 1},
        '2': {'MotorDriverNum': 1, 'ChannelNum': 0},
        '3': {'MotorDriverNum': 1, 'ChannelNum': 1},
# Comment
# 1. There are four DC motors, each denoted/represented by a Motor Config Dictionary.
# 2. A motor config dict has two elementa:
#      (a) MotorDriverNum which the the number of one of the two TB6612FNG motor drivers.
#      (b) Channel Number, denoting each of the two channel of the motor driver.
# 3. motorConfigDictList01 = motorConfigDictList_00_01_10_11 = the list of all four motor confict dictionaries.
# 4. motorConfigDictListDict is the Dict of motorConfigDictLists (only one such dict list for now)
motorDriverGpPinNumDict = { \
    '0': {'StdByPinNum'  : stdByPinNum0,
          '0' : {'In1PinNum'      : aIn1PinNum0,
                 'In2PinNum'      : aIn2PinNum0,
                 'PwmPinNum'      : aPwmPinNum0,
                 'PwmFreq'        : defaultPwmFreq,
                 'DutyCycle'      : defaultDutyCycle,
                 'IntPinNum'      : intPinNum0,
                 'IntPinCallBack' : intCallBack0,
          '1' : {'In1PinNum'      : bIn1PinNum0,
                 'In2PinNum'      : bIn2PinNum0,
                 'PwmPinNum'      : bPwmPinNum0,
                 'IntPinNum'      : intPinNum1,
                 'IntPinCallBack' : intCallBack1,
    '1': {'StdByPinNum'  : stdByPinNum1,
          '0' : {'In1PinNum'      : aIn1PinNum1,
                 'In2PinNum'      : aIn2PinNum1,
                 'PwmPinNum'      : aPwmPinNum1,
                 'IntPinNum'      : intPinNum2,
                 'IntPinCallBack' : intCallBack2,
          '1' : {'In1PinNum'      : bIn1PinNum1,
                 'In2PinNum'      : bIn2PinNum1,
                 'PwmPinNum'      : bPwmPinNum1,
                 'IntPinNum'      : intPinNum3,
                 'IntPinCallBack' : intCallBack3
# Comment
# 1. motorDriverGpPinNumDict specifies
#    (a) the GP pin numbers for the two TB6612FNG motor drivers ecah with two channels.
#    (b) the default values such as PWM frequency, duty cycles
def setupMotor(motorNum):
    motorConfigDict = motorConfigDictDict[str(motorNum)]
    motorDriverNum  = motorConfigDict['MotorDriverNum']
    channelNum      = motorConfigDict['ChannelNum']
    stdByPinNum     = motorDriverGpPinNumDict[str(motorDriverNum)]['StdByPinNum']
    in1PinNum       = motorDriverGpPinNumDict[str(motorDriverNum)][str(channelNum)]['In1PinNum']
    in2PinNum       = motorDriverGpPinNumDict[str(motorDriverNum)][str(channelNum)]['In2PinNum']
    pwmPinNum       = motorDriverGpPinNumDict[str(motorDriverNum)][str(channelNum)]['PwmPinNum']
    pwmFreq         = motorDriverGpPinNumDict[str(motorDriverNum)][str(channelNum)]['PwmFreq']
    dutyCycle       = motorDriverGpPinNumDict[str(motorDriverNum)][str(channelNum)]['DutyCycle']
    intPinNum       = motorDriverGpPinNumDict[str(motorDriverNum)][str(channelNum)]['IntPinNum']
    intPinCallBack  = motorDriverGpPinNumDict[str(motorDriverNum)][str(channelNum)]['IntPinCallBack']
    # *** Motor Driver Control Pin Setup ***
    stdByPin    = Pin(stdByPinNum, Pin.OUT)
    in1Pin      = Pin(in1PinNum, Pin.OUT)
    in2Pin      = Pin(in2PinNum, Pin.OUT)
    intPin      = Pin(intPinNum, Pin.IN, Pin.PULL_DOWN)
    stdByPin.high()
    in1Pin.low()
    in2Pin.low()
    # *** PWM Pin Setup ***
    pwmPin      = PWM(Pin(pwmPinNum))
    pwmPin.freq(pwmFreq)
    u16DutyCycle = int((dutyCycle / 100) * 65536)
    pwmPin.duty_u16(u16DutyCycle)
    # *** Interrupt Pin Setup ***
    intPin.irq(intPinCallBack, Pin.IRQ_FALLING)
    # *** Motor Control Dict ***
    motorControlDict = {'StdByPin': stdByPin,
                        'In1Pin'  : in1Pin,
                        'In2Pin'  : in2Pin,
                        'PwmPin'  : pwmPin,
                        'IntPin'  : intPin,
    motorStatusDict = {'Direction'   : defaultDirection,
                       'Speed'       : defaultSpeed,
                       'PwmFrequency': defaultPwmFreq,
    motorDict = {'MotorConfictDict' : motorConfigDict,
                 'MotorControlDict' : motorControlDict,
                 'MotorStatusDict'  : motorStatusDict
    return motorDict
# Comments
# 1. setupMotor(motorNum) perfroms the following things:
#    1.1 setup and intiralize control/pwm/interrupt pin objects from controlPinNum controlPin objects
#    1.2 setup interrupt call back functions
#    1.3 returns motorControlDict which is a dictionary of the motor's pin objects (stdBy, Input, Pwm, Interrupt)
def setupMotorList(motorNumList):
    motorControlDictList = [0] * len(motorNumList)
    for motorNum in motorNumList:
        motorControlDict = setupMotor(motorNum)
        motorControlDictList[motorNum] = motorControlDict
    return motorControlDictList
def setupMotorDirection(motorControlDict, directionName):
    if directionName =='Forward':
        motorControlDict['In1Pin'].low()
        motorControlDict['In2Pin'].high()
    elif directionName == 'Backward':
        motorControlDict['In1Pin'].high()
        motorControlDict['In2Pin'].low()
    return
def setupMotorSpeed(motorControlDict, speedName):
    pwmPin = motorControlDict['PwmPin']
    dutyCycle = dutyCycleDict[speedName]
    pwmPin.duty_u16(int((dutyCycle / 100) * 65536) )
    return
def moveMotorDirectionSpeed(motorControlDict, directionName, speedName):
    moveMotorDirection(motorControlDict, directionName)
    moveMotorSpeed(motorControlDict, speedName)
    return
def moveMotorDirectionSpeedList(motorControlDictList, directionName, speedName):
    for motorControlDict in motorControlDictList:
    return
def stopMotor(motorControlDict):
    return
def moveMotorForward(motorControlDict):
    return
def stopMotorList(motorControlDictList):
    return
# *** Test setup/stop/move motor functions ***
def testSetupMotor(motorNum):
    print('Begin testSetupMotor(), ', 'motorNum =', motorNum)
    motorControlDict = setupMotor(motorNum)['MotorControlDict']
    print('End   testSetupMotor().')
    return
def testSetupMotorList(motorNumList):
    return
def testSetupMoveMotor(motorNum, directionName, speedName, holdSecondsName):
    print('Begiun testSetupMoveMotor(), ', 'motorNum =', motorNum)
    motorDict = setupMotor(motorNum)
    motorControlDict = motorDict['MotorControlDict']
    hold(holdSecondsName)
    print('End   testSetupMoveMotor().')
    return
def testSetupMoveMotorList(motorNumList, directionName, speedName, holdSecondsName):
    print('Begiun testSetupMoveMotorNumList(), ...')
    print('End   testSetupMoveMotorNumList().')
    return
# *** BLDC Config/Fuctnions ***
dutyCycleDictBldc = {
    'VeryFast'     : 90,
    'Fast'         : 80,
    'Normal'       : 50,
    'Slow'         : 40,
    'VerySlow'     : 30,
def changeBldcMotorSpeed(motorControlDict, speedName):
    return
def setupBldcMotor(motorConfigDict):
    stdByPin.high()
    in1Pin.low()
    in2Pin.high()
    motorControlDictBldc = {'StdByPin': stdByPin,
                            'In1Pin'  : in1Pin,
                            'In2Pin'  : in2Pin,
                            'PwmPin'  : pwmPin,
                            'IntPin'  : intPin,
# Test functions
def testBldcMotor00():
    print('  Begin testBldcMotor00(), ...')
    motorConfigDict = {'MotorDriverNum': 0, 'ChannelNum': 0}
    hold('TwoSeconds')
    changeBldcMotorSpeed(motorConfigDict, 'VeryFast')
    hold('TwoSeconds')
    utime.sleep(2)
    changeBldcMotorDirection(motorConfigDict, 'CCW')
    utime.sleep(2)
    changeBldcMotorDirection(motorConfigDict, 'CW')
    changeBldcMotorSpeed(motorConfigDict, 'VerySlow')
    utime.sleep(2)
    print('  End   testSetupMotor00(), ...')
    return
# *** Sample test function call
#testBldcMotor00()
''' Old main test sample outputs
*** Sample Output  tlfong01  2021oct11hkt1955 ***
>>> %Run -c $EDITOR_CONTENT
Begin testSetupMoveMotorList(), ...
After 2 seconds, ...
    intPinNumList           = [0, 1, 2, 3]
    intGpPinNumList         = [4, 5, 6, 7]
    countPeriod (seconds)   = 0.1
    pauseTime (seconds)     = 0.1
    repeat count times      = 10
    countList = [296, 219, 291, 205] , min  205 , max  296 , dif  91 , avg  252
    countList = [286, 215, 295, 208] , min  208 , max  295 , dif  87 , avg  251
    countList = [288, 217, 300, 213] , min  213 , max  300 , dif  87 , avg  254
    countList = [301, 223, 298, 207] , min  207 , max  301 , dif  94 , avg  257
    countList = [271, 223, 308, 207] , min  207 , max  308 , dif  101 , avg  252
    countList = [287, 223, 305, 203] , min  203 , max  305 , dif  102 , avg  254
    countList = [277, 233, 306, 226] , min  226 , max  306 , dif  80 , avg  260
    countList = [282, 240, 299, 222] , min  222 , max  299 , dif  77 , avg  260
    countList = [294, 225, 307, 209] , min  209 , max  307 , dif  98 , avg  258
    countList = [299, 223, 303, 229] , min  223 , max  303 , dif  80 , avg  263
End   testSetupMoveMotorList(), ...
# *** Main Test ***
# *** Main ***
#testSetupMotor(motorNum = 0)
#testSetupMotorList(motorNumList = [0, 1, 2, 3])
#testSetupMoveMotor(motorNum = 0, directionName = 'Forward', speedName = 'VeryFast', holdSecondsName = 'TwoSeconds')
#testSetupMoveMotor(motorNum = 1, directionName = 'Forward', speedName = 'VeryFast', holdSecondsName = 'TwoSeconds')
#testSetupMoveMotor(motorNum = 2, directionName = 'Forward', speedName = 'VeryFast', holdSecondsName = 'TwoSeconds')
#testSetupMoveMotor(motorNum = 3, directionName = 'Forward', speedName = 'VeryFast', holdSecondsName = 'TwoSeconds')
testSetupMoveMotorList([0, 1, 2, 3], 'Forward', 'VeryFast', 'TwoSeconds')
# *** End ***
''' Sample output  tlfong01  2021nov17hkt2033
Begin setupMotor(), ...  tlfong01 2021nov1701
    intGpPinNumList         = [12, 13, 14, 15]
    countList = [0, 0, 0, 0] , min  0 , max  0 , dif  0 , avg  0
End   setupMotor(), ...
/ to continue, …
  ![[HRI 2020] YOLO - Your Own Living Object](https://forum.pi-top.com/uploads/default/original/2X/5/51c07eb81cbe1d87bb538a9dfcccbfda8ad33df5.jpeg)
