I’m hoping to extend the Wi-Fi range of the Raspberry Pi. How would you go about securing an external antenna with the pi-top [4]? Is there even a hole I could, at the very least, let an antenna cable dangle through?
The raspberry pi has no connector for external antenna, it is possible to do via a destructive modification done at your own risk but there is no support for this as the pitop uses the on board wifi.
Alternatively you can use a wifi dongle instead of using onboard
Ah I understand now, that clears things up a lot! Thanks for the explanation, a W-Fi dongle will do.
