Isn’t the power supply from the battery underpowered - if one wanted to get maximum performance from these motors?
The pi-top lithium battery is rated in specs :
38.85 Watt-hour - (11.1V, 3500mAH)
Each of the n20 Gear is rated:
Voltage (Nominal) - 12V
Current (Stall @ 12VDC) - 1600mA
I’m assuming this means max possible wattage for each motor at max would be
12V x 1.6A = 19.2 watts
With two of these, we’re already at 38.4 watts.
With 4 motors it would be 76.8 watts of power… which is much more than the pi-top battery is rated.
How could we provide motors with enough juice to get maximum output possible?
