Hi!
Few hours ago I received my Pi Top[4] and it is an awesome device. Thanks for building something so cool.
For getting familiar with it, I started with the “First Challenge” where I’ll write a small program that displays a rocket into the screen.
I had some issues that I have already solved (first thing I did, was to update and restart)
pitopwas not installed in the system. Since I’m familiar with Python, I created a folder for my projects and created a virtual environment. After activating the environment, I installedpitopwithpip install pitop - The
rocket_launch.pyscript complained then about the librarylibf77blas.so.3. I installed it withsudo apt install libatlas-base-dev - Then I got the following error:
Traceback (most recent call last):
File "rocket_launch.py", line 8, in <module>
miniscreen = Miniscreen()
File "/home/pi/Projects/venv/lib/python3.7/site-packages/pitop/miniscreen/miniscreen.py", line 22, in __init__
super(Miniscreen, self).__init__()
File "/home/pi/Projects/venv/lib/python3.7/site-packages/pitop/miniscreen/oled/oled.py", line 37, in __init__
self.__controller = OledDeviceController(self._redraw_last_image)
File "/home/pi/Projects/venv/lib/python3.7/site-packages/pitop/miniscreen/oled/core/device_controller.py", line 37, in __init__
self.__spi_bus = self.__get_spi_bus_from_ptdm()
File "/home/pi/Projects/venv/lib/python3.7/site-packages/pitop/miniscreen/oled/core/device_controller.py", line 92, in __get_spi_bus_from_ptdm
response = request_client.send_message(message)
File "/home/pi/Projects/venv/lib/python3.7/site-packages/pitopcommon/ptdm.py", line 388, in send_message
raise Exception(f"pt-device-manager reported an error ({response_object.message_id_name()})")
Exception: pt-device-manager reported an error (RSP_ERR_SERVER)
> pt-devices
Devices and peripherals handled by pt-device-manager:
OS release: 5.10.17-v7l+
Host device is pi-top [4]
> pi-top devices
HUB =========================================================================================================================================================================
pi-top [4] (v3.0)
PERIPHERALS =================================================================================================================================================================
[ ] pi-top [4] Foundation Plate
[ ] pi-top [4] Expansion Plate
[ ] pi-top Touchscreen
[ ] pi-top Keyboard
[ ] pi-topPULSE
[ ] pi-topSPEAKER (v1) - Left channel
[ ] pi-topSPEAKER (v1) - Mono
[ ] pi-topSPEAKER (v1) - Right channel
[ ] pi-topSPEAKER (v2)
[ ] pi-topPROTO+
> pi-top oled display "Hello World!"
Error on pitop-oled.run: pt-device-manager reported an error (RSP_ERR_SERVER)
It seems that there is a problem connecting or detecting the miniscreen. However, the mini screen is showing the battery level and if I press the arrows it shows different information (VNC, Wifi, LAN…)
Any ideas about how to continue?
Update: After reboot, the mini display shows the [4] logo display, later, an icon that I read as “Insert the SD Card” and then it turns off. The Pi-Top is working, though, and I can connect via SSH, VNC and run code.
Thanks!
