Hello.
I have 2 questions below:
Q1)
I bought pi-top4 diy & robotics kit yesterday.(incl. expansion plate)
I have tested servomotor, drive motor, camera and sensors.
Almost sensors are worked well in python SDK.
But, I found usb-camera doesnt work using expansion plates usb port. After I connected to pi-top4 usb port, then camera worked well.
All 2 ports from expansion plate are not working properly. I did re-assembled several time to check usb connection between rbp4 and pi-top4. Also usb ports are not working.
One more strange thing is that my expasion plate do not have usb-c pd port located middle of 2 usb ports which is different from product webpages : Expansion Plate Explained! (pi-top.com)
Is it different expansion plate model? How can I check right expansion plate with my robotics kit and pi-top4 board?
Q2)
In python SDK, there is IMU example. Is it also optional sensor? When I run IMU example, “This Expansion Plate doesn`t have an IMU” message is printes with Exception.
