hi, I have just bought a pi-top1 and thought it was just a simple Moular laptop project, but it since to be something built with enough functions to work with the rbp.
So I have a orange pi 5 because I was thinking it for multimedia and desktop use and for that use the rbp is sort of useless
My problem is that if I connect the original cable to the hub, I get no video signal, with my longer generic cable works but makes a blink every while, with an anker usb hub work well but it is too big to put it inside the case
I also bought another slim usb hub with hdmi but it doesn’t work, I search the specs, and its only 30hz, could that be the reason?
Does someone knows what is the problem with the hub with the hdmi signal? is there some settings that fix it? some slim usb to hdmi adapter or hub?
