Pi-top [3] RK3399 upgrade
Hi @Fixinpcs303 !
Sorry to hear about your experience with the Libre Computer Alta. It’s been a while but would you be willing to move your post to the Libre Computer Alta A311D upgrade thread so we don’t fill up this thread with posts not relevant to the RK3399 upgrade?
Or if you prefer, I could perhaps do so for you?
I realise I haven’t done a great job on this myself but it is the reason why I created the A311D thread…
I moved it there! Thanks for the tip.
Might need a new thread as I personally recommend the Banana Pi BPI-M5 as the most suitable upgrade for Pi-top 3. The M5 is so close to 3b layout that the cooling bridge covers the CPU perfectly and keeps it cool enough. The Amlogic S905X3 SoC on the M5 has good mainline support and 4GB DDR 4 makes it a good value upgrade from the original Pi 3b.
I’ve also been looking for a relatively easy way to update the Pi3 in my PiTop. I did end up getting the Orange Pi3 (thought there was a header for a fan, but as there isn’t, I may have to resort to soldering a fan via the GPIO…the bridge and hub are very cool, but they do make cooling tough).
One question for people who have done this upgrade…I note a lot of problems with various distros, and how sometimes packages aren’t available to let the speakers and battery work. I’m wondering why folks who go down this upgrade path don’t simply keep PiTopOS? Is there a reason that distro won’t work with the Orange SBC?
I haven’t got PiTop OS to install and work on the Orange Pi because I’m not skilled or patient enough. Not sure the latest PiTop OS works well on the RPi 3B or that PiTop are really interested in further development. The RPi 4B changed layout sort of stuffed up plans for a lot of startups.
However, I have found that the Orange Pi version of Raspberry Pi OS runs well. But don’t try to update/upgrade or you’ll get an OrangePi OS version of Debian which (for me at least) froze and crashed. Again, I’m not skilled or patient enough to keep pursuing this project.
I’m focusing more on the CrowPi for my RPi 4/5. Overall, though, I’ve quite gone off Raspberry Pi due to their habit of changing layouts with each iteration. Why the RPi 400 & 500 switcheroo?
Late model x86 laptops and new micro x86 boxes are much preferable and affordable.
Disclaimer: IANAE and a reply from pi-top staff would be far more reliable but AFAIUI, usually images written for the Broadcom SOCs as configured on RPi are quite different from how images are written for SOCs on other vendors’ SBCs so you can’t simply flash the images from RPi’s website to a microSD and expect that to boot on, say, a Radxa SBC - but it’s just possible you might on a Libre Computer SBC! (You can verify that on Libre Computer’s forum) However, Libre Computer is absolutely exceptional here because of the amount of effort they have put into their bootloader and SPI images to enable such functionality (i.e. it doesn’t seem to be possible on any other ARM-based SBC…maybe it might be possible on x86-based ones).
Anyone tried out a Radxa Rock 4A(+) / 4B(+) / 4SE in their pi-top [3] ? Should be able to make use of a lot of the support that has been drummed up by the Pine64 Community through the PinePhonePro, or by the IPFire Community supporting the RK3399 through NanoPi SBCs.
Sorry @Mickkbh, not sure how I missed your message! The Radxa Rock 4 really looks quite interesting, especially if you want to use your pi-top as a firewall-router with IPFire or run Mobile Linux distributions on it
WARNING! Can confirm the Radxa Rock 4 SE has the same issue as the Rock 3A: the HDMI port sticks out just too far (like 2 - 3mm) to be able to slide the Hubv2 far enough along for the cooling bridge to line up. I don’t know why Libre Computer is able to get the right part for the HDMI port in the right position but Radxa isn’t.
Anyone trying the 4 SE would probably benefit from this https://forum.radxa.com/t/flash-spi-on-4se-with-debian-11-bullseye/15994 and this https://xnux.eu/log/103.html
Also, if trying to turn your pi-top into a IPFire firewall+router, it’s worth considering https://forum.radxa.com/t/does-anyone-use-rock-pi-4-as-a-router/2754/25 and this for POE hats https://forum.radxa.com/t/is-raspberry-pi-poe-hat-compatible-with-rock-4se-poe-pins/12807/2
