Pi-Top [4] Spares - Batteries
I, too, have a Pi-Top [4] w/dead (really most sincerely dead) battery. It will only power up when the base plate (robot) is detached. 0% charge, but indicates charging. Is it true the battery is not user-replaceable? If it is, where can I buy one. If not, can I have it replaced if I send it in?
JimT
Unfortunately the manufacturer isn’t too forthcoming with a resolution. They asked if my device was under warranty, it isn’t. That’s the last I heard from them!
I too would appreciate some feedback on how to replace the battery or fix the battery firmware issue.
My pi-top[4] only ever shows Charging 0% in pi-topOS and on the OLED screen despite using the official pi-top charger.
When I run pi-top battery I get:
Charging State: 1
Capacity: 0
Time Remaining: 0
Wattage: 0
Rather than a completely depleated and dead battery, the above to me would suggest there is a firmware problem with the battery management.
The generic firmware update software seems to have done its job and I am running v5.4
Running pi-top devices returns HUB pi-top [4] (v5.4)
I also tried it running manually sudo pt-firmware-updater pt4_hub but there doesn’t seem to be any newer versions.
Any help or advice would be appreciated.
Many thanks
I found some info from users with similar problem who have fixed this using pt-battery-fw-update but it seems to be quite out of date. After getting it working by installing the WiringPi from an alternative repo, I get Error No: 121 in a loop instead or the expected Error No: 5 or no error at all.
A v2 seems to exist but I could not find it.
Hello.
I have exactly the same problem. I turned my pi-top after few weeks being not used, and it seems that battery has died.
pi-top battery
Charging State: 1
Capacity: 0
Time Remaining: 0
Wattage: 0
I tried to connect to different power adapters, using different cables and device still shows that battery is charging but still 0% and no progress.
pt-battery-fw-update also shows “Error No: 121”
That firmware updater you are referring to, it would update one of the chips on the battery ?
I’m inclined in trying to replace the 18650 batteries with new ones and re-solder the connector and board in place.If it’s the same 7.4v, I can’t see what would be wrong.
I see they use LG M26 cells, Anything would be better. But before I attempt this surgery, I would like an idea if this is the issue or not. The batteries did not last a year in my case, they were manufactured at the end of 2020, I mean… they probably have 10 cycles on them!
That’s cool idea - I can’t break it more. For me without properly working it is useless.
The question is: how to reach battery pack? I tried to remove cover with oled screen but no success.
There are two screws under black sticker at the bottom… but no luck after unscrewing them. Are there also other ones below green feet?
Update.
There is no update.
#forgotten
2 bottom screws behind rubber feet, and 2 black screws on the side, you need to remove the cover on top of the pie to see them.
Yep… Done. I reached the battery pack and disconnected it. Ordered spare “LG INR18650 M26” batteries - exactly the same as included in original package. Waiting for delivery.
The only doubts I have are connected with all those “security measures when working with such batteries”. I understand: “not short-circuit it”, “watch polarity”, but what about soldering? How to attach contacts back?
I would not have replaced them with the same model, they are notorious. If you ever want to try something else I would say stick to standard cells, 3.7v, and good brands like Samsung, Panasonic or Sony.
As for soldering, those are spot welded, very common for mass production of those cells. You can buy the same nickel strips, they are cheap. Tin and lead solder sticks well to nickel, use flux and it will be easy to recreate the same pack. Complete with shrink wrap! :wink:
Thanks for tips.
It’s done, but… it would be to easy if it was working :slight_smile:
I booted up with power adapter and it was showing 22%. It was also showing charging.
I left it connected overnight and now it dropped to 19% and still charging.
I cannot boot up on battery and after disconnecting power adapter it turns off.
Do I have to reset it somehow? Or something else broke in battery pack?
Screenshot 2023-02-12 at 14.54.13
I too have a battery issue on my pi-top [4] DIY. It will only run for a few minutes on battery power. So I have to have it on mains power all the time. The batteries must be generating a lot more heat than they used to as the fan is running at full speed most of the time although the CPU temp is generally between 38-44C.
I messaged tech support last week about getting spare battery packs but no response as yet.
Hummm says charging, but in reality it’s not? I have not done it yet myself. Looks like there’s a temp sensor cutoff and over voltage protection. Nothing else. If it were me, I’d check for 7.4v end to end. Then check the 7.4v on the red and black connectors. No clue if each black is negative and can be used independently or together. Same for red. They are likely pairs connected to the same lead.
The board should have an indication which is positive. Say bottom solder says positive, then the battery with positive on that slot, which means the other side will be negative and connect on the top.
Don’t know wha the white and yellow will do and how they are used, if used, for charging. Did you insulate the batteries? Those disks that were at the end of the batteries?
Thanks for suggestions. I will check the voltage and double check that I soldered it correctly.
Any News you can share?
Unfortunately had no time to work on it.
But I asked my friend for help to test it and check connections - he is electronics engineer. I will share info when I get it back.
Update: after re-soldering of new batteries and checking connections again the result is still the same. Battery is not charging although “charging state: 1”.
Not sure what was the reason… but maybe I fried the voltage protector when was soldering it for the first time or it just died.
Screenshot 2023-03-29 at 12.22.06
For me it’s end of the story :slight_smile: Already bought “bigger” UPS because at my place power interruptions happens quite often.
Thank you for your support.
BR
How did u get inside the pi-top to access the battery, im trying to open it myself but i dont wanna break it
Anything new on this issue? I also have a dead battery out of warranty and would love to replace it with a better battery.
