So this one can be a little frustrating to get working and gives you some nice additional remote space, certainly handy when, it can be common to reinstall pi-topOS to wipe edits
Automounting a Network Drive
The following steps is all done though the Terminal
Setting the credentials file
To start, first set a file that will have the username and password for accessing the network share.
- Open terminal Ctrl+Alt+T
- run the command nano ~/.smbcredentials
- All you need in this file is the following
username=YOUR_NETORK_SHARE_USERNAME password=YOUR_NETORK_SHARE_PASSWORD
chanfing YOUR_NETORK_SHARE_USERNAME and YOUR_NETORK_SHARE_PASSWORD to the username and password for your network share
- Save this file and close.
- I the Terminal enter
sudo chmod 600 ~/.smbcredentialsto set the correct permissions to the file
Create Share Location
In the Terminal type mkdir /media/networkshare you can change networkshare to anything you like. This location will be needed for the next step
fstab entry
Now we need to edit fstab.
- In the Terminal enter
sudo nano /etc/fstab - At the end you can add the following line
//SERVERNAME/SHAREFOLDER /media/networkshare cifs credentials=/home/pi/.smbcredentials,uid=1000,gid=1000 0 0
Replace the following
SERVERNAME = with the network computer that you are accessing A eg. //sever.local/SHAREFOLDER
SHAREFOLDER = the share folder that you want to mount | eg //sever.local/Dev
networkshare = the folder you made in the previous step, must be full path | eg. /home/pi/ShareDrive , does not have to be in /media
an example of the whole line
//orilla.local/dev /home/pi/DevDrive credentials=/home/pi/.smbcredentials,uid=1000,gid=1000 0 0
Note: Just so you know, an error will occur if you have a space between the comma and uid and gid
Validating it works
To test that the mount is working properly, in the Terminal, enter sudo mount -a you should see a folder on your desktop with the folder name you made for the share location. If everything is working correctly, after a reboot, the network drive should automount
