@duwudi Gave that a try, both with the gui configuration, and with raspi-config. No joy. Some strange things, however.
- When I tried to VLC into the box, I was refused entry for a bad user/password, a fact I know not to be true. Setting the name back resulted in normal operation.
sudo hostname new-name seemed to result in a name change, but that did NOT survive a reboot. I have not tested this extensively, however.
- The name of my router DOES resolve properly, but none of my other existing devices.
- Saved SMB locations in the File Manager resolve properly, at least when the original hostname is in use. I need to test this more.
- Various executable files fail (ping, mount, ssh) with
unable to resolve name or service.
- Only vaguely related: I get a static-y crackle-y sound from the pi-top speaker every time I connect with VLC. There have been one or two other times, but I haven’t quite isolated them.
Notes about pi-top and my network: The pi-top has been integrated into my network for more than a year, with no problems. It is not one of my ‘always-on’ devices, being powered up only when I’m working with it. As such, there are usually updates to perform when I turn it on. This last two months, I’ve been working on other things, so there were at least two kernel updates in the meantime. The problem I have described here started with the latest set of updates (about 130 of them), including both the Sirius, and the December kernel, as well as the foundation code update.
My next step will be to try a new sdcard with fresh flash to see what happens, though I expect to work perfectly well.---- EDIT: Just finished this process, and, guess what? No JOY! I am still not resolving names on my local net, unless the name is appended with .local!
THIS JUST IN: Appending .local to the network device name seems to work, which explains why File Manager saved locations work.
JimT
