Hey there,
we are working with Pi-Tops at the vocational school and I want to program scripts during the time I am not at school. (I only want auto-completion and those features…)
Is it possible to install the Pi-Top Python SDK on a Windows Machine?
I already tried to install it on the Windows Subsystem for Linux, but that did not work too. And also a manual install would not work…
Do you know a solution to this or is it just not possible? Thanks
The detailed error code is:
Getting requirements to build wheel … error
error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [61 lines of output]
warning: src/gevent/resolver/cares.pyx:38:0: The ‘DEF’ statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See github link was here: The ‘DEF’ statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See github link was here: The ‘DEF’ statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See github link was here because it changed.
[1/1] Cythonizing src/gevent/resolver/cares.pyx
warning: src/gevent/libev/corecext.pyx:326:0: The ‘DEF’ statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See github link was here
warning: src/gevent/libev/corecext.pyx:791:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See ***github link was here***: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See ***github link was here***: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See ***github link was here*** cython/cython/issues/4310
warning: src/gevent/libev/corecext.pyx:799:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See ***github link was here*** cython/cython/issues/4310
Compiling src/gevent/libev/corecext.pyx because it changed.
[1/1] Cythonizing src/gevent/libev/corecext.pyx
Compiling src/gevent/_greenlet_primitives.py because it changed.
[1/1] Cythonizing src/gevent/_greenlet_primitives.py
Compiling src/gevent/_hub_primitives.py because it changed.
[1/1] Cythonizing src/gevent/_hub_primitives.py
Compiling src/gevent/_hub_local.py because it changed.
[1/1] Cythonizing src/gevent/_hub_local.py
Compiling src/gevent/_waiter.py because it changed.
[1/1] Cythonizing src/gevent/_waiter.py
warning: src/gevent/_gevent_cgreenlet.pxd:112:33: Declarations should not be declared inline.
Error compiling Cython file:
cdef load_traceback
cdef Waiter
cdef wait
cdef iwait
cdef reraise
cpdef GEVENT_CONFIG
src/gevent/_gevent_cgreenlet.pxd:182:6: Variables cannot be declared with 'cpdef'. Use 'cdef' instead.
Compiling src/gevent/greenlet.py because it changed.
[1/1] Cythonizing src/gevent/greenlet.py
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 363, in <module>
main()
File "/usr/lib/python3/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 345, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/usr/lib/python3/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 130, in get_requires_for_build_wheel
return hook(config_settings)
File "/usr/lib/python3/dist-packages/setuptools/build_meta.py", line 162, in get_requires_for_build_wheel
return self._get_build_requires(
File "/usr/lib/python3/dist-packages/setuptools/build_meta.py", line 143, in _get_build_requires
self.run_setup()
File "/usr/lib/python3/dist-packages/setuptools/build_meta.py", line 267, in run_setup
super(_BuildMetaLegacyBackend,
File "/usr/lib/python3/dist-packages/setuptools/build_meta.py", line 158, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 294, in <module>
EXT_MODULES.append(cythonize1(mod))
File "/tmp/pip-install-qm27vn9f/gevent_48e6708889644530a9a6b464314ef626/_setuputils.py", line 237, in cythonize1
new_ext = cythonize(
File "/tmp/pip-build-env-rakjxoj9/overlay/local/lib/python3.10/dist-packages/Cython/Build/Dependencies.py", line 1129, in cythonize
cythonize_one(*args)
File "/tmp/pip-build-env-rakjxoj9/overlay/local/lib/python3.10/dist-packages/Cython/Build/Dependencies.py", line 1296, in cythonize_one
raise CompileError(None, pyx_file)
Cython.Compiler.Errors.CompileError: src/gevent/greenlet.py
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
