Anyone recommend the best size card to install new OS on Sirus.?
We usually recommend that you use 16GB SD Card so that you can store all your files. The OS itself is over 4GB so the extra room means you have plenty to play with!
Ok Good to know. I used a 8GB card and then when I tried to install the updates which failed citing no room left on card!!. I’ll look into getting a 16GB card
