Thank you, i’m going to investigate the HDMI refresh button this evening (not @ home)
But i’ve already tried without success to manually configure trough the config.txt.
By the way, the HDMI reset option do “This will set the resolution of all displays to the highest common resolution”, or the problem is that the highest resolution for the VNC virtual screen is 1920 and the on efor the monitor is also 1920 but its native is 1024, even if it supports 1920 (too small to be useful, it’s a 10" portable monitor). i think that the problem come form the VNC resolution by default.
If i change its resolution for something smaller, at the next start, it’s like nothing has changed.
Can i disable the VNC virtual screen (no need of it)? I’ve tried to disable VNC directly under PI os, but without success for my screen Issue.
