SPI 1 change to SPI 0
What is the command to set SPI to 0?
pi-top oled spi 0 does not work and errors.
What are the real commands?
@andrewjamesline are you wanting to change the OLED mini screen to use SPI 0 or do you want to use another device (like a HAT) that needs SPI0?
Change the mini screen to use SPI 0 as I have a Hat that needs SPI 1. May even want to disconnect mini screen from SPI altogether particularly as it is always blank once connected!!
I think you are looking at the latest docs, but are not yet using the latest SDK (which has not been released as an update yet). This will be out soon, but if you want to try it, then please try and install the SDK directly from the repository.
