I am using a pi-top [3] with a pi-topPROTO+ connected to the pi-topHUB v2 and a pi-topPULSE connected to the pi-topPROTO+.
Yesterday I installed a fresh Raspberry Pi OS “Bullseye” to a SD card, which runs very well and fast on the RPi3 B+. I included the pi-top Sirius repository as described at https://knowledgebase.pi-top.com/knowledge/pi-top-and-raspberry-pi-os to get support for the pi-top features in Bullseye.
It seems, that a lot changed since my last installation of the pi-top stuff on a Raspberry Pi OS, all seems to concentrate on the “pt-device-manager” which seems to handle all the pi-top peripherals now.
I installed it and the battery symbol appears and the pi-topPULSE speaker seems to work fine as HDMI audio output.
But immediately after the GUI loads, I get an error message in the upper right corner of the desktop:
“Failed to load HAT overlay”
“dterror: not a valid FDT - err -9”
I am quite sure, it has to do with the pi-topPULSE, because it is (as far as I know) the only device inside my pi-top which contains a HAT eeprom. Is there a dtb-file missing for the pi-topPULSE?
Any ideas how to fix this?
Thank you in advance.
Regards, Thorsten
