Having trouble with the keypress listener function when the pi-top is connected via VNC. Should this work - or does another keyboard need to be connected, and if so how?
How can one see which library functions are available in the Further system?
@Almac44 have you checked it is working with a keyboard/screen connected directly to the pi-top? Just to be clear, is it this lib you are trying to use?
Have tried it with an FHD touch display and bluetooth keyboard. Does not seem to work
Interestingly the Pi-top mini screen write application works OK with Vnc or Bluetooth keyboard input
@Almac44 ok got it, if you could add a new issue here then our team or somebody in the community will look into it
