If you haven’t already done so, check this out:
One thing that needs to be done is an update to the default widgets. If you would like to download and replace your widgets and install all available widgets as I have done, here is a drive folder with a clean setup, that will install clock, disk usage, memory, and uptime widgets.
For the most part, the widgets are the same. I may have added a different format for the uptime, but that just makes it easier to read the time so you don’t have to convert from seconds.
@duwudi, also, can we get the developers to update these on the next update? I’ve updated certain values to correspond with new versions
